July 26, 2017, 16:07 |
Cannot find stream function in CFD-Post?
Khalid Baker
Rep Power: 17 |
Hello I attempted to plot stream function in CFD-Post but I do not find it? may somebody tell me where i can find it please?
regards Khalid Baker |
July 27, 2017, 06:07 |
Abhinand
Rep Power: 9 |
I guess you must enable it from data file quantities while you calculate the solution in setup tab File-> data file quantities select all the necessary quantities you want to write and maybe after then you will get the stream function in the CFD post Cheers |
July 27, 2017, 06:12 |
#3 | |
Khalid Baker
Rep Power: 17 |
Hello I cannot find file quantities in file menu in CFD-Post where I can find it exactly?
July 27, 2017, 06:15 |
Abhinand
Rep Power: 9 |
It will be in the setup menu. While calculating the solution you must write the stream functions also to view in CFD post
July 27, 2017, 07:19 |
Rep Power: 16 |
July 27, 2017, 07:28 |
Abhinand
Rep Power: 9 |
while doing your simulation in set up tab. Before your click on calculate for iterating the solution to get converged, you must go to File -> Data file quantities -> Stream function.
Only after you write the values of stream function you can access in CFD post If you are having doubts, have a look at this https://www.sharcnet.ca/Software/Ans...e_options.html cheers |
CFD post: Find area with variable above a certan value | evcelica | CFX | 4 | March 7, 2014 20:04 |
[blockMesh] error message with modeling a cube with a hold at the center | hsingtzu | OpenFOAM Meshing & Mesh Conversion | 2 | March 14, 2012 09:56 |
[blockMesh] BlockMesh FOAM warning | gaottino | OpenFOAM Meshing & Mesh Conversion | 7 | July 19, 2010 14:11 |
latest OpenFOAM-1.6.x from git failed to compile | phsieh2005 | OpenFOAM Bugs | 25 | February 9, 2010 04:37 |
Error with Wmake | skabilan | OpenFOAM Installation | 3 | July 28, 2009 00:35 |
