July 30, 2017, 12:14 |
Falling box tutorial
David
Rep Power: 9 |
Hello everyone. im working my thesis on the movement of particle on a submerged jet flow.
For the moment im having some troubles so i want to run the tutorial on a mm system. i modify the six dof udf on the mass and inertia values. and i run the case but when the box enter in contact with the water the case crash. so the question its under wish parameters should i run the case? #include "udf.h" #define BMODULUS 2.2e9 #define rho_ref 1000.0 DEFINE_PROPERTY(water_density,c,t) { real rho; real p, dp, p_operating; p_operating = RP_Get_Real("operating-pressure"); p = C_P(c,t); dp = p-p_operating; rho = rho_ref/(1.0-dp/BMODULUS); return rho; } DEFINE_PROPERTY(water_speed_of_sound,c,t) { real a; real p, dp, p_operating; p_operating = RP_Get_Real ("operating-pressure"); p = C_P(c,t); dp = p-p_operating; a = (1.-dp/BMODULUS)*sqrt(BMODULUS/rho_ref); return a; } DEFINE_SDOF_PROPERTIES(falling_box, prop, dt, time, dtime) { prop[SDOF_MASS] = 2.7e-6; prop[SDOF_IZZ] = 4.5e-13; printf ("\n2d_test_box: Updated 6DOF properties"); } Under-Relaxation Factors 0.5 for Body Forces 0.8 for Turbulent Viscosity. Solution Initialization 0.001 m2/s2 for Turbulent Kinetic Energy and 0.001 m2/s3 for Turbulent Dissipation Rate. 1 for air Volume Fraction. |
July 31, 2017, 19:13 |
David
Rep Power: 9 |
August 6, 2017, 11:53 |
David
Rep Power: 9 |
Up. If someone not understand I need to run the falling box tutorial on mm. So I want to know which parameters I need to modify to run. Thanks for any help
Sent from my Redmi Note 4 using CFD Online Forum mobile app |
August 10, 2017, 15:12 |
David
Rep Power: 9 |
August 25, 2017, 08:55 |
David
Rep Power: 9 |
Anyone. I'm still looking for a solution to run the tutorial on mm.
[DesignModeler] change/increase model size box | oewnce932c | ANSYS Meshing & Geometry | 5 | April 8, 2022 01:37 |
I get different results when I scale the 'falling box' tutorial | Hossein1 | FLUENT | 7 | August 19, 2017 02:52 |
How to calculate moment of inertia for the falling box? | Hossein1 | FLUENT | 1 | January 14, 2017 20:04 |
Water drop falling too slow - Interfoam | danvica | OpenFOAM Running, Solving & CFD | 5 | November 20, 2013 08:54 |
STAR-CD Tutorial | shekhar aryal | STAR-CD | 4 | March 22, 2010 03:25 |
