Problems with Biomass Gasification
Like Tree1Likes
  • 1 Post By Chalumpol
Old   February 18, 2017, 00:14
Lightbulb Problems with Biomass Gasification
Chalumpol
Chalumpol is on a distinguished road
Hello Everyone..
I'm researching about Biomass Gasification in downdraft gasifier in Thailand and i would like to simulate the temperature distribution and mole fraction in the gasifier with CFD and i'm newbie with it.
I found a paper that is closed to my work. the link is https://www.researchgate.net/publica...IT_BUNCH_WASTE.I have read that paper and i try to study from that. My model is on below of the paragraph.
My model is refer to that paper, 2D Realization k-e model, with steady state. i used species transport with 9 species as CH4,CO,N2,H2O,O2,C<S>(use in particle surface reactions),H2,CO2,and Volatiles. i used species transport with finite rate/eddy dissipation and the reaction i add in reaction tab is
Volatile decomposition reaction
1. Vol + 0.174O2 + 0.457H2 ---> 0.268CO + 0.371H2O + 0.357H2 +0.003N2
Gas Phase Reaction
2. 2CO + O2 ---> 2CO2
3. 2H2 + O2 ---> 2H2O
4. CO + H2O ---> CO2 + H2
Particle Surface Reactions
5. C<s> + O2 ---> CO2
6. 2C<s> + O2 ---> 2CO
7. C<s> + 2H2 ---> CH4
8. C<s> + H2O ---> COH2
the volatiles which is calculated from coal calculator is balanced from the producer gas, so I have to add hydrogen to balance the equation.
boundary condition:
drying ---> 373k
pyrolysis ---> 673k
gasification ---> 1073k
reduction ---> 573k
air inlet(mass flow rate) ---> 1.68e-3 kg/s (2 nozzles)
fuel inlet (mass flow rate) ---> 2.78e-3 kg/s
My surface body is air. and all the wall temp is 300 kelvin with the coefficient of heat transfer 10 W/m2. and internal emissivity is 0.6. The solution control is set as default. And solution initiation is hybrid.The solution method is used SIMPLE. Least-squared Cell based,the pressure methods is PRESTO!, and the others are First Order Upwind.
When i run calculations, the result goes to 9 iterations and stopped running with the error "Error: received a fatal signal (Segmentation fault). Error Object: #f". and the value at all of the species are zero.
The question is how can i check the cause of the error and how can i solve it?
Thank you for your kind answer.
nitz5 likes this.
Chalumpol is offline   Reply With Quote
Old   August 29, 2017, 03:57
Default problem with chemkin
Nityanand Hiraprasad Kushwaha
nitz5 is on a distinguished road
since you mentioned the paper you are following I got interested in your query because I am also doing a simulation using same the paper but I am not getting the required solution. Also conc. of CO and H2 are main species to focus upon but without chemkin I am getting nothing.
can u please help in chemkin?
Also iam uploading meshing pics and convergence pics.conver.txt
mol. conc. of CO
PLEASE HELP ME IN CHEMKIN!
nitz5 is offline   Reply With Quote
biomass gasification, gasification
Biomass gasification model: floating point error Jamiebell94 STAR-CCM+ 0 December 3, 2016 15:18
Needed Benchmark Problems for FSI Mechstud Main CFD Forum 4 July 26, 2011 12:13
Does anyone help me in biomass dryer simulation? pichai FLUENT 0 May 19, 2010 04:05
Problems bout CFD model of biomass gasification, Downdraft gasifier wanglong FLUENT 2 November 25, 2009 23:27
