Moving bed reactor
Like Tree1Likes
  • 1 Post By Borsche
Old   March 23, 2006, 05:03
Default Moving bed reactor
A. Al-Zoubi
Hi all,
I want to simulate a moving sphere bed in a cylindrical tube. Hot air inlets from the tube side near the bottom and leaves near the top. Cold spheres enters from the top and leave the bottom of the tube. The Spheres flow rate at inlet equals that at the outlet and the tube is always full. The speed of the spheres is slow in comparison to the air.
I want to determine the temperature distribution at steady state.
Any hint is welcome.
Thanks a lot in advance.
Ahmad
Old   May 13, 2014, 17:50
Boris
Borsche is on a distinguished road
I'm working on a similar problem. The Eulerian model seems to be the best choice as the solid and fluid phase are exchanging heat and momentum. Discrete modeling for this situation is unnecessary as the particles are moving very slowly and the collisions between particles can be ignored. The situation is that the particles are slowly being removed from the bottom of the tube.
My question is how to specify the boundary conditions such that one of the phases is entering and the other is leaving. Is there a boundary condition 'type' that can satisfy this requirement?
Thanks
Borsche is offline   Reply With Quote
Old   May 14, 2014, 13:06
Boris
I have found multiple threads asking this same question, with no answer given in any of them.
Does anyone know how to set up the boundary conditions for counter current multiphase flow? Where the inlet for one phase is the outlet for the other?
Thanks
shengzi-qingqing likes this.
Old   September 11, 2017, 07:57
vignesh
vigneshveeramani is on a distinguished road
Originally Posted by Borsche View Post
Thanks
Hi Porsche, I'm also working on same problem. In my case I considered porous domain inside furnace rather than using multi phase models.. I got the pressure and velocity distribution correctly but I couldn't get temperature distribution properly..
Sent from my SM-J730GM using CFD Online Forum mobile app
vigneshveeramani is offline   Reply With Quote
urgent... multiphase cfd model of packed bed reactor.( VOF MODEL using) balu@gold6 FLUENT 4 July 26, 2012 10:37
how to model heat transfer inside a slow moving bed? bigfans FLUENT 1 October 9, 2009 00:12
Fixed bed reactor.....you can help...I am sure!! Amrrefay FLUENT 0 June 6, 2009 06:58
Moving Bed Reactor Ahmad Al-Zoubi Main CFD Forum 1 March 21, 2006 15:45
Bubbling Fluidized Bed reactor burning biomass Mattias FLUENT 6 June 8, 2004 02:53
