How to modify injection/droplet temperature through journal or similar |
September 22, 2017, 03:28 |
Martin
Rep Power: 9 |
Hi everyone,
I am wondering if there is any solution to the following problem: - I do multiphase calculations with water droplets in air to calculate evaporation and condensation rates - I need to do quite a lot of simulations with different droplet temperature By now I did not find a way to change the injection temperature via journal files or something similar, so that I wouldn't have to modify every single case but just change a value in a text file or something. Any suggestions are appreciated. Cheers Martin |
dpm, injection, journal file, temperature |
Static temperature and Total temperature | Jong-Yoon | FLUENT | 0 | September 25, 2016 01:42 |
Calculation of the Governing Equations | Mihail | CFX | 7 | September 7, 2014 06:27 |
Inlet won't apply UDF and has temperature at 0K! | tccruise | Fluent UDF and Scheme Programming | 2 | September 14, 2012 06:08 |
monitoring point of total temperature | rogbrito | FLUENT | 0 | June 21, 2009 17:31 |
Problems With Journal When Writing Forces To File | Andrew | FLUENT | 2 | September 23, 2005 02:12 |
