September 28, 2017, 09:40 |
turbulent flow
Rep Power: 9 |
please i want to simulate the experience of snyder and lumley1971 (Some measurements of particle velocity autocorrelation functions in a turbulent flow) with fluent 2d
but the problem that i don't now how to define the grid so that the flow became turbulent the inlet velocity is 6.55 m/s length : 4 m width:0.46 m so in the result the flow is laminar and the velocity reste constant along the trajectory i need to perturbe the velocity from the inlet . in the experience they use a grid to generate the turbulence please someone help me Last edited by soufiane002; September 29, 2017 at 04:35. |
September 28, 2017, 19:01 |
Missing ref
Svetlana Tkachenko
Rep Power: 14 |
"Studies of the Behavior of heavy Particles in a Turbulent Fluid Flow" does not have the figures you attached. Please provide the reference.
September 29, 2017, 04:41 |
#3 | |
Rep Power: 9 |
and the two figures is an exemple of the experience. |
Problem with divergence | TDK | FLUENT | 13 | December 14, 2018 06:00 |
Why can i use a laminar solver for a turbulent flow? [Heat transfer problem] | blackbow | CFX | 1 | November 22, 2016 04:42 |
Particle deposition on circular cylinder in turbulent flow | Julian K. | CFX | 1 | October 3, 2011 17:51 |
Difference between recirculation zone and turbulent flow region | ashtonJ | Main CFD Forum | 0 | September 16, 2011 03:46 |
Inviscid Drag at subsonic, subcritical Mach # | Axel Rohde | Main CFD Forum | 1 | November 19, 2001 12:19 |
