Display Error after Scaling Mesh
Old   October 18, 2017, 04:15
Question Display Error after Scaling Mesh
Gerrit B
gerritb is on a distinguished road
Hi all,
I accidentally created my surface mesh in ANSA with millimeter (mm) as the length unit instead of meter (m). I already created the volume mesh in TGrid without noticing, and even ran my simulation.
Now I want to fix that mistake and used the 'scale mesh' function in Fluent (under 'general'->'mesh'->'scale'). Unfortunately, now the mesh is not displayed correctly, but seems to be twisted. However, when I compute the area of particular faces or the volume of particular cell zones, the correct value in the correct unit (m2 for area, m3 for volume) is computed. Running the simulation also works without any error message, the solution converges. But also in the post-processing, the display of the model is twisted in the same way as in the mesh.
The fact that everything else works fine leads me to the conclusion, that it is just a display error. Does anyone have an idea what could cause this error, and more importantly how to fix it?
Thanks,
Gerrit
gerritb is offline   Reply With Quote
Old   October 18, 2017, 10:18
Vangelis Skaperdas
vangelis is on a distinguished road
Hi Gerrit.
Do you have just surface mesh in ANSA?
Is it geometry macros or FE-mod mesh?
What do you mean by twisted? Can you post an image?
Have you tried volume meshing in ANSA?
cheers
Vangelis
vangelis is offline   Reply With Quote
Old   October 18, 2017, 20:33
Gerrit B
Hi Vangelis,
Thanks for your reply.
Apparently it was only a display error. Restarting the computer solved the problem. Too easy, didn't considder doing that. Sorry
Old   October 19, 2017, 03:54
Vangelis Skaperdas
You may want to check you have the latest graphics driver
scale, scale mesh
[ICEM] 2D hybrid mesh (unstructured mesh highly dependent on structured mesh parameters) shubham jain ANSYS Meshing & Geometry 1 April 10, 2017 05:03
[snappyHexMesh] No layers in a small gap bobburnquist OpenFOAM Meshing & Mesh Conversion 6 August 26, 2015 09:38
[snappyHexMesh] Layers:problem with curvature giulio.topazio OpenFOAM Meshing & Mesh Conversion 10 August 22, 2012 09:03
errors when installing openfoam2.1 on ubuntu12.o4 hewei OpenFOAM Installation 5 May 29, 2012 07:43
