November 15, 2017, 01:41 |
Y+ values
yun
Rep Power: 10 |
it is adviced that y+ values should be around 1 when enhanced wall treatment is selected. We can check that value from “adapt” section. But it is the max value!! Minimum and average values can be checked from Reports. So my questions are 1-which value should we take into consideration? Max, min or average? 2-if min is very low( for example 1e-04) does this effect the simulation? Thanks!! |
November 15, 2017, 08:02 |
Jaesan Yoon
Rep Power: 8 |
if y+ value is very small, it affects badly for your convergence of your simulation
min and max value range should be chosen based on your tur. model |
November 15, 2017, 19:53 |
Alexander
Rep Power: 34 |
If you are using wall treatment than y+ should be significantly larger than 1,
for standard wall treatment it is around 30-50, for enhanced 50-200 Once you have made y+ ~ 1 you do not need wall treatment at all, switch it off Best regards |
November 16, 2017, 02:53 |
#4 | |
yun
Rep Power: 10 |
it is clearly discussed in user manual and in the forum that y+ needs to be equal to 1 for EWT. now you say 50-200?!? |
November 16, 2017, 10:26 |
#5 | |
Lucky
Rep Power: 66 |
AlexanderZ is confusing wall treatment for wall functions.
Some user judgment is required. It's entirely up to you. There is no laws regarding how to do CFD. My harsh response is to recommend you to wikipedia to better understand statistics: https://en.wikipedia.org/wiki/Statistics But a more useful response... Quote:
Obviously you can have an average of 0.5 or 0.1 even with a max of 1. So the avg gives a better sense of what the typical quality is. Some people (myself included) also like to have a high min y+ in order to maintain suitably low cell count. Usually this is more of an optimization problem to minimize computational cost. Really what do you want your mesh to look like? At the end of the day it is your mesh and your CFD and not someone else's. 2 It is unlikely you can get a y+ that small for practical flows. If you did achieve such a low y+, it's not necessarily a problem. However, it's probably a hint that your solution is a bad one (because it's really hard to get such a small y+). Usually the problem is to get a small enough y+, why complain if it's small? At some point you need to stop being paranoid and just hit the damn run button, get some results, and learn something. |
TimeVaryingMappedFixedValue | irishdave | OpenFOAM Running, Solving & CFD | 32 | June 16, 2021 06:55 |
using chemkin | JMDag2004 | OpenFOAM Pre-Processing | 2 | March 8, 2016 22:38 |
Velocity values are normal but pressure values are too big | rv82 | OpenFOAM Running, Solving & CFD | 4 | April 13, 2015 03:59 |
Setting patch field values equal to internal field values | leroyv | OpenFOAM Programming & Development | 1 | October 21, 2014 15:49 |
Plotting raw data values | Wilesco | Siemens | 0 | January 5, 2006 05:34 |
