November 15, 2017, 07:35 |
Issues of Fluent Setup
Cetengfei Zhang
Hi everyone,
I found that when I run the 'Setup' for my ANSYS Fluent 18.2, everything is fine but I can't see any image, just like the picture I showed below. As you can see for the database window that everything is done and fine, even it shows that the mesh is prepared to display, but there is nothing in the mesh window, all black. I tried move the scale and sight for the window but I am quite sure that there is no image in that. Can somebody tell me what is going on here and how can I fix this? |
November 16, 2017, 10:31 |
Lucky
Rep Power: 66 |
This might not actually fix anything but try to create another graphics window. One of the buttons will let you split your window into 2, 3, etc. Maybe the mesh will magically pop up when you create a new graphics object.
Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 13:41 |
The fluent stopped and errors with "Emergency: received SIGHUP signal" | yuyuxuan | FLUENT | 0 | December 3, 2013 22:56 |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 10:54 |
problem in using parallel process in fluent 14 | aydinkabir88 | FLUENT | 1 | July 10, 2013 02:00 |
FLUENT Speed Issues on Cluster | cfd23 | FLUENT | 2 | April 3, 2010 23:43 |
