December 28, 2017, 05:38 |
Modelling Cavitation
Pina
Rep Power: 8 |
When modelling cavitation on a hydrofoil, what are the values of inlet and outlet pressure one should enter to obtain a specific cavitation number?
December 28, 2017, 09:20 |
Daniel Edebro
Rep Power: 10 |
The cavitation number is a measure of how close you are to cavitation and it can be defined for every point according to the following formula:
Ca = (p_loc - p_vap)/(0.5*rho*U_inf^2) Where U_inf is the velocity far from the hydrofoil. What do you mean by "optain a specific cavitation number"? |
December 28, 2017, 09:47 |
Pina
Rep Power: 8 |
What i meant to say is that I wanted to carry out the simulation using different cavitation numbers. This can be done by changing the magnitude of velocity.
I initially thought I had a wrong set up however the simulation was not converging due to incorrect initialization. |
December 28, 2017, 10:57 |
Daniel Edebro
Rep Power: 10 |
Ok, maybe this is arguing about semantics but I wouldn't say that you are "using different cavitation numbers". The cavitation number is a part of your solution the same way that pressure is. Or in other words, the cavitation number is always an output never an input to a calculation.
On a side note: If you are doing valve analysis there is a global parameter called cavitation index (sigma) that is defined as: Sigma = (P_up - P_vap) / (P_up - P_down) This parameter can be used as an input value for a CFD calculation. |
December 28, 2017, 13:59 |
Pina
Rep Power: 8 |
I am analysing the cavitational effects on hydrofoils and examining its effect on the lift coefficient.
Cavitation modelling | Memboro | CFX | 6 | November 26, 2015 05:56 |
cavitation modelling | GJM1991 | OpenFOAM Running, Solving & CFD | 0 | April 29, 2015 04:06 |
Modelling Cavitation in Pumps | BigPapi34 | OpenFOAM Running, Solving & CFD | 0 | August 29, 2012 10:29 |
Cavitation Modelling Options | Torque_Converter | CFX | 2 | August 12, 2012 12:08 |
Cavitation modelling !!! | ROOZBEH | Fidelity CFD | 5 | May 21, 2004 01:39 |
