2D Forced Roll Damping Simulation using FLUENT |
December 29, 2017, 02:48 |
Hello everyone,
Now I am working on predicting roll damping of a ship hull section, but now I have some questions. The hull section that I used is the SS5 section of the S60 ship, and the dimension of the hull section was the same with Ikeda's experiments. However, I did not have a good result. I am seeking for help. On the model section a harmonic roll motion is imposed by moving the complete body and computational mesh at a prescribed period T and amplitude φ0. The structured grids were generated by ICEM. In FLUENT, I used dynamic mesh method. In my case, the 2D midsection mesh zone rotated around the roll axis. There is an interface between stationary zone and rigid moving zone. The following is my UDF code, could please help me find if there is some wrong? Thanks! UDF code: #include"udf.h" #define freq 0.84 #define ampl 0.175 #define density 998.2 #define GRAVITY 9.81 int id=14; DEFINE_CG_MOTION(int_block_roll, dt, vel, omega, time, dtime) { omega[2] = 2*M_PI*freq*ampl*cos(2*M_PI*freq*time); } DEFINE_EXECUTE_AT_END(exe_end) { real x_cg[3],m_glob[3],f_glob[3],sita,time,m_plus; real x[ND_ND],A[ND_ND]; FILE *fp; Domain *domain=Get_Domain(1); face_t f; Thread *tf=Lookup_Thread(domain,id); time = CURRENT_TIME; x_cg[0] = 0.0; x_cg[1] = 0.0; m_plus=0.0; sita = ampl*sin(2*M_PI*freq*time); if(!Data_Valid_P()) return; Compute_Force_And_Moment(domain,tf,x_cg,f_glob,m_g lob,TRUE); begin_f_loop(f,tf) { F_CENTROID(x,f,tf); F_AREA(A,f,tf); if(x[1]<0.0) m_plus+=density*GRAVITY*x[1]*fabs(x[1]*A[0]-x[0]*A[1]); } end_f_loop(f,tf) m_glob[2]+=m_plus; #if !RP_NODE fp=fopen("roll.txt","a"); fprintf(fp,"%f,%f,%f,%f,%f,%f\n",time,sita,f_glob[0],f_glob[1],NV_MAG(f_glob),m_glob[2]); fclose(fp); #endif } |
dynamicmesh forcedroll |
Start new Ansys Fluent Simulation automatically | Malue | Fluent UDF and Scheme Programming | 1 | October 4, 2017 01:48 |
Which Multiphase Model Should be selected in Fluent for my below described simulation | oberstar | Fluent Multiphase | 0 | September 28, 2017 12:05 |
Flux reports for transient simulation in Fluent | khaham | FLUENT | 11 | April 19, 2017 07:44 |
Simulation on fluent 14 | NAD | FLUENT | 0 | September 11, 2013 02:05 |
Fluent Remote Simulation Facility Service (RSF) di | Rami | FLUENT | 2 | June 4, 2008 05:38 |
