3 boundary conditions at a time on a single wall surface
Old   August 4, 2012, 18:26
Question 3 boundary conditions at a time on a single wall surface
n7310889
n7310889 is on a distinguished road
I'm simulating a steady state 3D conjugate heat transfer problem of a parabolic trough concentrating collector receiver. Here receiver is simply a annular tube (consists of a large tube with a smaller concentric cylinder inserted) through which syltherm oil is passing to collect the heat energy.
The receiver gets concentrated radiation (which is reflected from a parabolic trough mirror). This radiation creates transversely a high non uniform heat source (or may be heat flux) around the tube. A portion of this radiation is absorbed by the oil, and the rest is lost due to radiation and probably convection from the tube surface.The boundary condition for the heat source might be an UDF defining a function for heat source/heat flux around the tube, and will make sure that the heat flux is non-uniform according to the reflected radiation profile.
Now, I'm wondering how can I accommodate these THREE boundary conditions on a single surface:1. a function defining a non-uniform heat flux, 2. radiation loss and 3. convection loss. Someone proposed me to give SOURCE TERM, instead of heat flux, and activate "MIXED" option (that is both radiation and convection option) from the drop down list of the boundary condition for the wall surface. But, this source term should provide a uniform heat energy around the tube body instead of a non-uniform heat flux, shouldn't it?
Could any of you please suggest me how can I accommodate all of these three boundary conditions on a single wall surface?
n7310889 is offline   Reply With Quote
Old   August 12, 2012, 20:10
n7310889
It seems no body knows how to solve the problem!!!!!!!!!!!
Old   January 6, 2018, 02:45
Binjo Geo
binjoes is on a distinguished road
Did you solve the problem
binjoes is offline   Reply With Quote
3d simulation, cht, single wall 3 boundary
Wind turbine simulation Saturn CFX 58 July 3, 2020 01:13
Domain Imbalance HMR CFX 5 October 10, 2016 05:57
Superlinear speedup in OpenFOAM 13 msrinath80 OpenFOAM Running, Solving & CFD 18 March 3, 2015 05:36
IcoFoam parallel woes msrinath80 OpenFOAM Running, Solving & CFD 9 July 22, 2007 02:58
Could anybody help me see this error and give help liugx212 OpenFOAM Running, Solving & CFD 3 January 4, 2006 18:07
