Flow through pipe - porous media defining
Old   January 12, 2018, 09:46
Default Flow through pipe - porous media defining
Jigs
jmex is on a distinguished road
Hello everyone,
I want to define porosity, i have pressure drop and flow rate. Can anyone help me how to define porous media in ansys fluent? Or how do i calculate parameters to define porosity?
Thanks in advance.
jmex is offline   Reply With Quote
Old   January 12, 2018, 10:20
ehsan
e_cfd is on a distinguished road
Simply, you need to define two zones in design modeler, then in fluent you can active the porous zone from the cell zone menu (which actually adds a sink term to the momentum equation ).
Regards,
e_cfd is offline   Reply With Quote
Old   January 12, 2018, 10:40
Jigs
yes i have done that, but what should be my inputs to porous zone parameter. i mean i have pressure drop and flow data. How do i input that in porous zone?
Old   January 12, 2018, 10:56
ehsan
Usually you need to know the viscous resistance coefficient (in terms of permeability), inertial resistance coefficents ( just if the velocity is high enough), and porosity. Also you have to enter the direction of each coefficient (if the medium is not isotropic). for more info read the following basic tutorial:
https://www.sharcnet.ca/Software/Flu...ug/node276.htm
If you have pressure drop and velocity you can calculate the permeabilty from darcy or more comprehensive models (depending on your problem)
porous, porous domain
Multiphase Porous Media Flow - Convergence Issues VT_Bromley FLUENT 7 May 14, 2020 16:34
Flow through two combined porous media with diffrent permeability Sandee Main CFD Forum 0 March 28, 2015 10:35
Flow through porous media near well-borne I_Fedorov FLUENT 0 October 29, 2014 15:05
How do model two phase granular flow in Porous media? bahman FLUENT 1 December 6, 2012 04:39
Can LES be used in porous media flow? Jin Main CFD Forum 0 October 19, 2006 08:50
