January 18, 2018, 19:17 |
Rotating cone on a stationary plate
Emad Ramadan
I am trying to model a viscometer with ansys-fluent. I am not sure if I need to use sliding mesh or if a rotating frame would suffice. The viscometer is basically a cone with its apex sitting at the origin, a flat plate is at a distance below the apex of the cone, and the area between the cone and the plate is filled with fluid. The cone is to rotate (about the Y-axis) at a certain RPM and I need to figure out the tangential velocity in the Y-direction and shear stress profile-on the surface of the plate. Thanks a lot for your help, I am new and I am struggling so any tips or pieces of advice are highly appreciated, Emad |
January 19, 2018, 00:07 |
Uwe Pilz
This can be modeled easily with a moving wall, which may be set as b.c.
Uwe Pilz -- Die der Hauptbewegung überlagerte Schwankungsbewegung ist in ihren Einzelheiten so hoffnungslos kompliziert, daß ihre theoretische Berechnung aussichtslos erscheint. (Hermann Schlichting, 1950) |
Opening frame type (rotating, stationary)? | urosgrivc | CFX | 0 | July 3, 2017 05:24 |
Rotating or stationary domain in pump/turbine cavity | Christian Høy | CFX | 3 | March 17, 2017 06:03 |
Car external aerodynamic with wheel spinning issue | hokhay | FloEFD, FloWorks & FloTHERM | 2 | August 18, 2016 04:23 |
Convert DFT of pressure in rotating frame to stationary frame | CFD-123 | FLUENT | 0 | February 12, 2015 17:51 |
Parallel Plate Rheometer vs Cone & Plate | beginner | Main CFD Forum | 0 | March 19, 2003 11:49 |
