Fluent Boundary Condition and Mass flow rate ? |
January 24, 2018, 04:01 |
Hells Blade
Rep Power: 8 |
I am getting Mass flow rate of -0.22220825 at Outlet and 0.22212315 at Inlet so higher values at the outlet which is not physically possible.
Generally mass flow values at outlet should be closer to inlet values for the simulation to converge I am currently using pressure inlet and pressure outlet( the condition idicates that the flow becomes 0 at outlet ) Do I then take my mass flow inlet values and run a diff simulation using mass flow inlet values and should i use pressure bc at the outlet ? |
January 24, 2018, 12:10 |
Lucky
Rep Power: 66 |
That's a difference of 0.01%. Fortunately/unfortunately, you are not doing real world physics but trying to do it numerically on a computer. There is such a thing as numerical errors.
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
mass flow in is not equal to mass flow out | saii | CFX | 12 | March 19, 2018 05:21 |
Multiphase flow - incorrect velocity on inlet | Mike_Tom | CFX | 6 | September 29, 2016 01:27 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
