Syntax error while interpreting a simple velocity profile UDF
Old   February 7, 2018, 10:26
Default Syntax error while interpreting a simple velocity profile UDF
Pavel
Pavel Mihailovski is on a distinguished road
Hi everyone,
I am trying to interpret a UDF file. I am doing this for the first time, so right before I go with my particular problem, I tried to add this simple UDF (an example which I took from the FLuent library) just to check whether or not FLuent will recognize it.
However, after I put my file in the adequate folder, browsed it and clicked interpret file, I get the following massage:
Error: /home/pmihailovski/velocity_profile.c: line 2: syntax error.
Can you help me with this line 2: syntax error?
I am sending you the well-known example of the code right below:
Looking forward to hearing from you.
Pavel
#include "udf.h"
DEFINE_PROFILE(velocity_profile,t,i)
real x[ND_ND]; /* this will hold the position vector */
real y;
face_t f;
begin_f_loop(f,t)
F_CENTROID(x,f,t);
y = x[1];
F_PROFILE(f,t,i) = 1.1e5 - y*y/(.0745*.0745)*0.1e5;
end_f_loop(f,t)
Pavel Mihailovski is offline   Reply With Quote
Old   February 8, 2018, 13:13
fanch33 is on a distinguished road
did you try to compile the UDF instead of interpret it? Are you sure you have a compiler on your computer?
Fanch
fanch33 is offline   Reply With Quote
Old   February 8, 2018, 15:12
Pavel
Originally Posted by fanch33 View Post
Fanch
No, I haven't tried, thanks for the advice. Can you suggest any compiler, and give me a brief follow up in case you are familiar with the procedure?
looking forward to hearing from you again, cheers!
Old   February 8, 2018, 15:17
nm
nvarma is on a distinguished road
The code is fine. No syntax error.
Was this udf created on the same Linux machine? Seems like a "line ending" error.
If it was on a windows machine Dos2Unix might be of help. Or you could use notepad++ and save it with appropriate encoding.
nvarma is offline   Reply With Quote
Old   February 8, 2018, 15:20
Pavel
I used a simple .tex document file. I am working on Windows. I'm gonna try with notepad++ and come back at you. Can you be a little bit more specific about this Dos2Unix treatment? Is it complex?
Thanks
Old   February 8, 2018, 15:22
nm
Here you go: https://stackoverflow.com/questions/...ion-in-notepad
Old   February 8, 2018, 15:24
Pavel
Thank you, my friend, cheers!
3D UDF Paraboilc Velocity Profile (Can't Maintain) Sing FLUENT 12 August 7, 2017 07:25
velocity profile in a simple cylindrical flow tube Diger FLUENT 0 December 29, 2016 22:05
UDF syntax error Ratel Fluent UDF and Scheme Programming 4 May 23, 2015 06:15
3D Velocity profile for turbulent flow Kirill Fluent UDF and Scheme Programming 3 July 17, 2014 09:42
udf for velocity profile in a geometry having two inlets shubham208011 Fluent UDF and Scheme Programming 0 April 6, 2009 16:13
