February 10, 2018, 23:07 |
heat conduction in 2D
Rep Power: 14 |
I am modelling a 2D cylinder with a fluid flow inside. there is a heat on the outer surface of the cylinder (Temperature). the heat sould transfer to the inside fluid by conduction. the problem is here, there is no heat goes to the fluid. I know there is no shell conduction in 2D, but how can I make the heat pass the cylinder ? I have draw the fluid with the cylinder, and did mesh both. Thanks in advance |
February 14, 2018, 17:32 |
Lucky
Rep Power: 66 |
You need an interface between cell zones to couple them. If you meshed it correctly, you have two "walls" that each have the "coupled" boundary condition in the thermal tab.
February 14, 2018, 21:23 |
Rep Power: 14 |
Thanks for the replay.
I have got new 4 walls, two of them with coupled boundary conditions and other two just a regular walls. Is that correct ? thank you |
February 14, 2018, 21:39 |
Rep Power: 14 |
Sorry, but I have another question.
Since, the heat is on the outer surface, that suppose to go to the inside fluid through the cylinder by conduction. Am I need to set any boundary for the new 2 walls (not the coupled ones), or just leave it for the outer surface ? thanks |
Thermally coupling 1D gas flow to 3D heat conduction in solid | Pyotr | CFX | 5 | March 6, 2017 21:46 |
Enforce bounds error with heat loss boundary condition at solid walls | Chander | CFX | 2 | May 1, 2012 20:11 |
Phase Change Heat Conduction | hawkeye321 | OpenFOAM | 14 | April 30, 2011 14:24 |
Conduction heat not balanced? | Nepal | CFX | 7 | May 31, 2005 11:51 |
Euler equations with heat conduction! | salem | Main CFD Forum | 10 | August 2, 2004 03:16 |
