February 20, 2018, 13:43 |
Pressure outlet boundary condition
Rep Power: 13 |
Dear all
In fluent, for outlet, I use pressure outlet with a defined gage pressure. For backflow, I use normal to the boundary method. So, for pressure outlet defined above, is it a mixed condition of Dirichlet condition and Neumann condition? Any reference to the above would mean a lot to me. I work on Swirling flow. I look forward to your response. Regards, Kukka |
February 20, 2018, 14:41 |
Lucky
Rep Power: 66 |
The pressure outlet boundary condition is indeed a mixed-like boundary condition (when there is reversed flow).
If there is no backflow then the pressure outlet applies the pressure to all cells and it behaves like a Dirichlet BC. If there is reversed flow (or backflow) for some cells then you need to supply information for what is coming in. For those cells where there is reversed flow, it is some kind of inlet and you have several options for how to constrain this reversed flow. However, you can't control which cells have reversed flow or not so that this is not really a mixed BC either. You are able to fix the pressure but you can only constrain the velocity. So it's like a mixed BC but not really. |
February 21, 2018, 03:49 |
Rep Power: 13 |
Dear LuckyTran,
Thanks a lot for the explanation. It was useful for me. Regards, Kukka |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
Radiation in semi-transparent media with surface-to-surface model? | mpeppels | CFX | 11 | August 22, 2019 07:30 |
Question about adaptive timestepping | Guille1811 | CFX | 25 | November 12, 2017 17:38 |
Static pressure boundary condition at outlet | jennz | CFX | 4 | February 11, 2014 03:29 |
RPM in Wind Turbine | Pankaj | CFX | 9 | November 23, 2009 04:05 |
