March 3, 2018, 13:55 |
calculating mass flow rate
mohit dhoriya
Rep Power: 8 |
hi,
im doing a transient cfd analysis of flow through pipe system which has 2 inlet and 2 outlet. i want to calculate the total mass flow rate from starting till end but i couldnt find how to do it. Can anyone help me? |
March 5, 2018, 09:56 |
Cees Haringa
you can make a surface monitor for mass flow rate through a surface (inlet or outlet) under report definitions. This gives you the flowrate at every timestep - integrate the whole thing in time to get the total. I assume you use pressure inlets or so? For a velocity inlet, you can just get it from velocity * area * time.
March 6, 2018, 11:54 |
mohit dhoriya
Rep Power: 8 |
thankyou for your reply
cfd - post, fluent 14, transient 3d |
Mass flow rate: calculation v/s computation | beguxa | FLUENT | 5 | December 2, 2018 21:02 |
Specify mass flow rate for periodic boundary conditions in channel flow | lion1990 | OpenFOAM Running, Solving & CFD | 1 | July 9, 2018 17:46 |
mass flow rate in DPM steady tracking | Roule | FLUENT | 4 | June 1, 2015 10:44 |
mass flow rate... | sanjar | OpenFOAM Running, Solving & CFD | 1 | December 2, 2013 00:09 |
Calculating mass flow rate | cfd novice | FLUENT | 1 | April 3, 2008 18:31 |
