Subsonic Nozzle's Pressure Inlet and Thrust
Old   March 18, 2018, 17:58
Default Subsonic Nozzle's Pressure Inlet and Thrust
Dingkun Guo
dguo31 is on a distinguished road
I am analyzing a subsonic nozzle, but have some problems with setting up boundary conditions of the inlet of the nozzle. I have known the pressure, temperature and mass flow rate at the inlet. Since it looks like not practical to set both the mass flow rate and the pressure when using the mass flow inlet, I am using pressure inlet instead. However, the residue blows up very fast. I am not sure what's wrong. It does converge when I use mass flow inlet, but I can not set the pressure.
How do I measure the thrust from the nozzle? Would it be possible to compute it from the mass flow rate and flow velocity from surface integral reports?
Thanks,
dguo31 is offline   Reply With Quote
FloEFD: Flow through a nozzle and then into a domain Supriya_GM FloEFD, FloWorks & FloTHERM 2 April 19, 2017 01:19
Static pressure results all over the place Easyqus FLUENT 1 January 12, 2016 05:37
Thrust in Axial flow fan for different inlets acoustica CFX 8 April 24, 2014 03:44
boundary conditions for a pipe underwater jpc Main CFD Forum 5 January 9, 2013 15:57
Thrust calculation Tony CFX 4 July 9, 2012 11:48
