Propeller blade setting. Is it correct?
Like Tree1Likes
  • 1 Post By vasava
Old   April 19, 2018, 08:09
Default Propeller blade setting. Is it correct?
Naveen Kumar Gulla
Naveen Kumar Gulla is on a distinguished road
Hi everyone,
I'm trying to simulate the propeller blade in fluent using MRF. Basically, I'm trying to get a similar result with the experimental data, to get the thrust and torque. However, the torque that I'm getting is a way too much different than the experimental value. I'm not sure what could have gone wrong.
I'll start with explaining the method that I'm using. After some search and reading in the forum, I found that to study a propeller blade, it needs to be segregated into three different sections, the front zone for translation velocity, a rotating zone that contains the propeller blade, and the downstream outlet section. I'm using k-eps model.
The figure below shows the setup that I'm currently using for my analysis, Kindly please advice me if there is anything wrong.
Naveen Kumar Gulla is offline   Reply With Quote
Old   April 19, 2018, 08:11
Default Some more images
Naveen Kumar Gulla
Some more images
Old   April 19, 2018, 08:13
Default Some more images2
Naveen Kumar Gulla
some more images
Old   April 19, 2018, 08:30
kiran Ambilpur
kiran is on a distinguished road
Send a message via Skype™ to kiran
please refer to the fluent tutorials, there are plenty of examples also available online.
kiran is offline   Reply With Quote
Old   April 19, 2018, 08:34
Naveen Kumar Gulla
I have seen most of the videos, but no one has cared about results. They have shown only the procedure
Thank you for your reply kiran
Old   April 19, 2018, 12:59
Kushal Puri
Kushal Puri is on a distinguished road
I am nowhere seeing the RPM given in the BCs.
Kushal Puri is offline   Reply With Quote
Old   April 19, 2018, 13:15
Naveen Kumar Gulla
I have given to sta_dom
Old   April 19, 2018, 13:23
Kushal Puri
But it has to be given to rotary domain right ?
Old   April 22, 2018, 11:19
Naveen Kumar Gulla
I have watched few tutorials from learncax and also viewed in Fluent help that when we are using SRF approach we can give motion to the fluid domain instead of rotor.
Thank you
Old   April 23, 2018, 07:59
Paritosh Vasava
vasava will become famous soon enough
...when we are using SRF approach we can give motion to the fluid domain instead of rotor.
You are using MRF and not SRF. Thus, you have to give the rotating condition accordingly.
Your setup seems ok except that you have set your stationary part as rotating and rotating part as stationary. This is already pointed out by Kushal.
The aim of most tutorials is to demonstrate how a certain scenario can be simulated with fluent. All the official Ansys tutorial discuss results and some verification methods briefly. Of course you yourself will have to figure out how you post-process your case to get relevant results. No tutorial will do it for you.
I recommend that you go through the rotating machinery training material from Ansys. It has some very good tutorials and theory explanations about frame of reference usage. Here is the link.
Kushal Puri likes this.
vasava is offline   Reply With Quote
3D CFD simulation of propeller blade - Turbulent viscosity limited to viscosity ratio Quentin_C FLUENT 1 April 4, 2017 05:32
Propeller blade setting. Is it correct? zizie FLUENT 20 October 16, 2016 10:18
[TurboGrid] Slotted rotor Blade using Turbogrid drcsm ANSYS Meshing & Geometry 0 March 15, 2016 00:26
Ansys Matlab integration: 'propeller blade shape optimization' usamatoson ANSYS 1 November 22, 2015 06:16
[snappyHexMesh] determining displacement for added points CFDnewbie147 OpenFOAM Meshing & Mesh Conversion 1 October 22, 2013 09:53
