April 24, 2018, 03:02 |
heat flux in fluent
Chaitanya
Rep Power: 9 |
Dear members,
I am doing flow boiling simulations and I have given linearly increasing temperature profile at the wall. Do I want to know that how fluent calculates the heat flux at different axial locations? Thanking all in advance |
April 24, 2018, 16:35 |
Lucky
Rep Power: 66 |
For laminar flows, it uses Fourier's law (thermal conductivity times the temperature gradient). For turbulent flows, it uses an analogous relationship but one has to keep in mind that the law of the wall is invoked.
This is not a separate calculation, but done when you setup and solve the energy equation (because the energy flux across the cell face is needed). |
April 26, 2018, 01:20 |
heat transfer coefficient
Chaitanya
Rep Power: 9 |
heat trannsfer coefficient value given by fluent is not matching with heat transfer coefficient calcualted by h=q/(Tw-Tl)
What would be the possible reason? Thanking you |
April 26, 2018, 11:19 |
Lucky
Rep Power: 66 |
Did you set the reference temperature in the reference values?
If in doubt compare heat fluxes and not heat transfer coefficient. |
April 26, 2018, 12:03 |
Chaitanya
Rep Power: 9 |
Thank you for your suggestions
Heat Flux due to electron flow in GTAW welding process | redwanamit034 | FLUENT | 0 | August 11, 2017 17:26 |
Radiation interface | hinca | CFX | 15 | January 26, 2014 17:11 |
How to define the heat flux in the interior interface between two phases | fangdian | FLUENT | 1 | November 18, 2013 07:23 |
Heat Flux at Internal walls or Fluid Solid Interface | Mahi | CFX | 3 | October 1, 2012 02:18 |
How to find the inbuilt equation in fluent for Heat Transfer Flux? | rohitjvbibin | Main CFD Forum | 0 | October 26, 2010 05:51 |
