May 5, 2018, 03:52 |
Aerodynamic analysis for F-15E wing
Tariq
Hi, I'm working on the graduation project to get the bachelor's degree in aeronautical engineering. The project is an aerodynamic analysis of the F-15 wing by using Ansys fluent 18.2.
But at maximum AOA I got CL of 0.45 only and it is known that the CL of Fighter aircrafts are between 1.8 and 3. I tried videos on Youtube but nothing new. Please help ! Boundry condition type: Rectangular include: inlet, outlet, symmetry (root face) and wing surface (upper and lower) viscous model: k-e relizable air characteristics: by default inlet type: velocity inlet with velocity say 100 m/s or any velocity .. and supersonic/initial gauge pressure=0 outlet type: pressure outlet with value=101325 Pa (sea level condition) reference value is ok i choose inlet and insert aera=29.7 m^2 and length=3.84 m methods type SIMPLE and all under second order for high accuracy iteration is 1200 until values converted note: i use design moduler for changing the angle of attack, also the maximum angle of attack is 22 degree with lift coefficient = 0.45 only |
fluent subsonic wing analysis problem | fatihcoban | FLUENT | 0 | August 3, 2016 09:41 |
3-D wing analysis problem | arjit | FLUENT | 14 | June 17, 2013 14:39 |
Wing analysis | montazerhodjat | CFX | 8 | August 3, 2012 08:55 |
Aerodynamic Analysis | Simulationengineer | CFX | 3 | October 5, 2010 20:15 |
AERODYNAMIC NOISE ANALYSIS | Nicolas | CFX | 5 | April 4, 2007 12:41 |
