May 7, 2018, 01:03 |
Calculating required heat flux
Nived Sankar
Rep Power: 8 |
How to calculate required heat flux for a cylinder to be at constant temperature?
May 7, 2018, 10:46 |
Lucky
Rep Power: 66 |
If there's a heat flux, it can't be a constant temperature. So zero.
May 9, 2018, 08:13 |
Nived Sankar
Rep Power: 8 |
The problem is in case of a bundle of pipes arranged above each other. The pipes need to be kept at constant temperature. It is heated internally. So what should be the heat flux given to individual pipes to keep them at constant temperature?
CEL expression for calculating heat flux to be applied as surface boundary condition | shadnia | CFX | 14 | August 20, 2018 18:32 |
Sign of Heat Flux at wall | Kyung | FLUENT | 2 | February 26, 2016 16:25 |
Error finding variable "THERMX" | sunilpatil | CFX | 8 | April 26, 2013 07:00 |
Heat Flux Profile at Fluid-Porous Interface | Hitch8 | CFX | 4 | December 15, 2012 09:57 |
Heat Flux at Internal walls or Fluid Solid Interface | Mahi | CFX | 3 | October 1, 2012 02:18 |
