May 10, 2018, 16:52 |
Courant number
Omid Shekari
Rep Power: 9 |
Do I get fake convergence by lowering current number (just like lowering relaxation factors)??
What is exactly courant number in a simple and apprehensible explaination? |
May 10, 2018, 20:31 |
Lucky
Rep Power: 66 |
The Courant number is how far information/disturbances travel in one time-step. When the Courant number is >>1, your disturbance has the potential to skip through the mesh, which leads to many interesting problems (including numerical instability). Having a smaller Courant number actually improves the accuracy of your simulation because you are better able to track the evolution of these disturbances.
URF's are a different monster and better to interpret in a steady-state example. URF's affect only the convergence behavior and do not improve your accuracy. They are artificial/numerical bandaids to prevent a simulation from becoming unstable. |
May 11, 2018, 05:01 |
Omid Shekari
Rep Power: 9 |
My simulation is also steady state,I’m just using “coupled” scheme and courant appears in “solution control”.
So how could it be interpreted in a steady state case? |
May 11, 2018, 16:07 |
Lucky
Rep Power: 66 |
The Courant number in the COUPLED P-V scheme is actually a URF but has the interpretation of a Courant number multiplier. Check out this post #14 which has some equations to convert from this Courant number to URF's. A Courant number of Infinity corresponds to a URF of 1. Depending on the version of Fluent you use, the default Courant number is 200 or 100 which are close to a URF of 0.99. In this steady state example, lowering the Courant number does get you fake convergence just as lowering a URF would.
May 13, 2018, 14:48 |
Omid Shekari
Rep Power: 9 |
Thanks so much
courant number increases to rather large values | 6863523 | OpenFOAM Running, Solving & CFD | 22 | July 5, 2023 23:48 |
[snappyHexMesh] Error snappyhexmesh - Multiple outside loops | avinashjagdale | OpenFOAM Meshing & Mesh Conversion | 53 | March 8, 2019 09:42 |
multiphaseEulerFoam (OF2.3.0) : Courant number explodes when running in parallel | Mehrez | OpenFOAM Running, Solving & CFD | 10 | May 18, 2016 11:44 |
Sudden jump in Courant number | NJG | OpenFOAM Running, Solving & CFD | 7 | May 15, 2014 13:52 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
