Quadrupole magnet coil heat transfer
Old   May 15, 2018, 11:34
Default Quadrupole magnet coil heat transfer
Qbz
Jakub
Qbz is on a distinguished road
I received a task to do a heat transfer analysis of a quadrupole magnet. It consists a magnet coil with a water flowing inside a circular hollow cooling the magnet. Please find here:
https://www26.zippyshare.com/v/hPiLv4q3/file.html
https://www26.zippyshare.com/v/ve3FXThn/file.html
the catia and .stp file showing the construction. Could you do it or show something similar? I have been watching many videos covering similar topics, but I found it very hard to implement in my case from my perspective. The biggest problem I have is with setting the boundaries, The magnet generates 0,95kW and the water inlet temperature is 298K and the ambient temperature is 293K.
The problem is that I get all the errors regarding the solver and the divergence, actually I tried to do it in several different ways, but always no success.
I have also been wondering if this could be done with the steady-state thermal workbench module.
I would really appreciate any help.
Thank you.
Best regards,
Kuba
Qbz is offline   Reply With Quote
Two-sided Wall Heat Transfer BC - No Separate Solid Mesh and No Heat Transfer Coeff swahono OpenFOAM Running, Solving & CFD 10 October 15, 2018 05:43
UDF for mass and heat source with heat transfer rajendra1 Fluent UDF and Scheme Programming 35 October 13, 2017 04:04
Interphase mass transfer of a reaction cfx_ws1992 Main CFD Forum 0 May 15, 2017 21:42
Question about heat transfer simulation Anna Tian Main CFD Forum 0 January 25, 2013 18:53
Convective Heat Transfer - Heat Exchanger Mark CFX 6 November 15, 2004 15:55
