Ansys fluent
Old   May 17, 2018, 07:09
Default Ansys fluent
Charles
SirCharles is on a distinguished road
Please I am having difficulties starting from the design modeller stage. My major challenge now is on how to separate the three (3) regions of my fluid.
Consider a vertical tube heated uniformly over its length and fed with subcooled water at its based at such a rate that the liquid totally evaporated over the length of the tube.
There are basically three regions which I will be experiencing in the uniformly heated pipe as the sub-cooled liquid is fed up the tube.
(Region 1) Single-Phase Liquid Only
(Region 2) Mixture of Liquid and Vapour
(Region 3) Single-Phase Vapour Only
Please I need a guide from the design modeller aspect.
Please do I need to define the three separate region from the design modeller stage? I'm I going to consider three(3) Eulerian Phases?
Is there any recommended tutorial video that I can use as a guide?
Waiting for your kind response.
Charles
(charlesokon50@yahoo.com)
SirCharles is offline   Reply With Quote
GPU acceleration in Ansys Fluent flotus1 Hardware 63 May 12, 2023 02:48
How to open Icem mesh in Ansys Fluent? emmkell FLUENT 27 February 6, 2018 03:34
Using ANSYS Fluent 18.0 on workstations with multiple network cards and PBS Pro cheezum Hardware 0 February 28, 2017 10:23
How to combine ANSYS Fluent and Structural analysis? diwakar ANSYS 2 June 18, 2015 12:07
error in opening fluent in ansys workbench tmeysam92 ANSYS 3 March 12, 2013 06:10
