May 17, 2018, 07:09 |
Ansys fluent
Charles
Please I am having difficulties starting from the design modeller stage. My major challenge now is on how to separate the three (3) regions of my fluid.
Consider a vertical tube heated uniformly over its length and fed with subcooled water at its based at such a rate that the liquid totally evaporated over the length of the tube. There are basically three regions which I will be experiencing in the uniformly heated pipe as the sub-cooled liquid is fed up the tube. (Region 1) Single-Phase Liquid Only (Region 2) Mixture of Liquid and Vapour (Region 3) Single-Phase Vapour Only Please I need a guide from the design modeller aspect. Please do I need to define the three separate region from the design modeller stage? I'm I going to consider three(3) Eulerian Phases? Is there any recommended tutorial video that I can use as a guide? Waiting for your kind response. Charles (charlesokon50@yahoo.com) |
GPU acceleration in Ansys Fluent | flotus1 | Hardware | 63 | May 12, 2023 02:48 |
How to open Icem mesh in Ansys Fluent? | emmkell | FLUENT | 27 | February 6, 2018 03:34 |
Using ANSYS Fluent 18.0 on workstations with multiple network cards and PBS Pro | cheezum | Hardware | 0 | February 28, 2017 10:23 |
How to combine ANSYS Fluent and Structural analysis? | diwakar | ANSYS | 2 | June 18, 2015 12:07 |
error in opening fluent in ansys workbench | tmeysam92 | ANSYS | 3 | March 12, 2013 06:10 |
