missing case file in some design points using workbench updates |
January 28, 2016, 20:19 |
Hi all,
I was using the parameter set -> design points on Ansys workbench 15 to do fluent simulations. I checked the boxes for exported the design points. The updates finished successfully. But when I tried to postprocessing the design point project by opening its corresponding workbench file, the case file is missing. It happens to only some of the design points. Others do have the case file and I can postprocess these successfully. Does anyone know why and how to solve the missing case file in design point project problem? Please. I don't want to run each of them individually again. Thank you. ~ Jen |
December 28, 2021, 05:49 |
Bharath
Rep Power: 7 |
Hi Does anyone have an explanation or solution to overcome this, have a similar issue.
Thanks! |
ansys 15 workbench, case file, design points, fluent |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
Problem compiling a custom Lagrangian library | brbbhatti | OpenFOAM Programming & Development | 2 | July 7, 2014 11:32 |
[swak4Foam] funkySetFields compilation error | tayo | OpenFOAM Community Contributions | 39 | December 3, 2012 05:18 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
[blockMesh] Axisymmetrical mesh | Rasmus Gjesing (Gjesing) | OpenFOAM Meshing & Mesh Conversion | 10 | April 2, 2007 14:00 |
