June 1, 2018, 22:13 |
convergence problem regarding fluent
Rep Power: 8 |
Recently, I've faced a very strange convergence problem in fluent. I'm trying to get a concept understanding the fluid condition inside a cycle distributor.
So the following geometry and mesh was created. mesh quality is good due to simple structure. when I'm modeling flow inside from location A and outside from location B1~B18. I set location A to mass flow inlet, location B1~B18 to pressure outlet, the calculation can quickly converge to a solution, and result is reasonable. However when I'm trying to model the reverse direction flow, which means the flow goes in from location B1~ B18, goes out from location A. the convergence is really odd. this time, I set location B1~B18 to pressure inlet or mass flow inlet or velocity inlet, location A to pressure outlet, the calculation never converge, but give results like below (The second picture shows the residual plot). After checking regarding the monitoring point/surface pressure, flow, it's also keeping oscillating. Any one knows why this happens? is the number of inlets to much? Really thanks Last edited by funkvps; June 2, 2018 at 02:28. |
June 2, 2018, 00:54 |
Lucky
Rep Power: 66 |
That's definitely a converged solution. Why do you say it's not converged? You probably need to recalibrate your understanding of convergence.
June 2, 2018, 02:26 |
Rep Power: 8 |
Sorry for my mis typing, the second picture shows the residual vs time, as indicated, the residual keeps high all the time. When I check the check point/surface pressure/flow, it's also oscillating.
Convergence | Centurion2011 | FLUENT | 48 | June 14, 2022 23:29 |
Problem in compiling fluent UDF lunched from MATLAB | cfdman10 | Fluent UDF and Scheme Programming | 16 | December 5, 2019 05:32 |
Fluent - license problem. | Marcin | FLUENT | 3 | April 13, 2018 16:33 |
convergence problem in ansys fluent | israr.iitp | Visualization & Post-Processing | 0 | September 5, 2015 06:01 |
Problem in using parallel process in fluent 14 | Tleja | FLUENT | 3 | September 13, 2013 10:54 |
