setting boundary conditions for heat transfer |
June 13, 2018, 13:11 |
#21 |
Rep Power: 10 |
Check out this image.
June 13, 2018, 13:21 |
#22 | |
Rep Power: 9 |
Thanks for your reply. I set this geometry because the temperature change along depth is really small. Also if I just model the bottom part, I don't know the inlet temperature though. |
June 13, 2018, 13:23 |
#23 |
Rep Power: 10 |
I think you'll have to run some hand calculations to approximate the inlet temperature. Unfortunately, it's been a while since my heat transfer days, so I won't be of much help.
June 13, 2018, 15:51 |
#24 | |
Rep Power: 9 |
Thanks, |
June 13, 2018, 16:01 |
#25 |
Rep Power: 10 |
Unfortunately, I'm not sure. I don't work with the Energy model at all, and I couldn't even find the operating condition you were looking at.
June 13, 2018, 16:15 |
#26 |
Rep Power: 9 |
okay, thanks all the same.
Foam::error::PrintStack | almir | OpenFOAM Running, Solving & CFD | 91 | December 21, 2022 04:50 |
Wind turbine simulation | Saturn | CFX | 58 | July 3, 2020 01:13 |
Out File does not show Imbalance in % | Mmaragann | CFX | 5 | January 20, 2017 10:20 |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 21:16 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
