Moving wall imposed with rotation and revolution |
May 9, 2018, 10:32 |
Yandong Gu
Rep Power: 9 |
I would like to impose a constant rotating velocity (Speed 300 rad/s) on a shaft wall by using Moving Wall, but the shaft also revolves as a rigid body. So the rotation-axis origin is changing with time, e.g. X(t), Y(t), Z(t). sorry for my horrible English and hope you can understand me. Is there any approach to set the central point changing with time? Thank you very much! |
May 14, 2018, 07:01 |
Yandong Gu
Rep Power: 9 |
Help, please
June 20, 2018, 01:25 |
Yandong Gu
Rep Power: 9 |
Help, please
June 20, 2018, 02:10 |
Rep Power: 18 |
You could use a user-defined function to describe the time-dependent boundary condition with a DEFINE_PROFILE macro. A similar question has been asked at: Moving wall with velocity profile where you could start from the UDF suggested and then apply the translation of the origin.
June 20, 2018, 02:17 |
#5 | |
Yandong Gu
Rep Power: 9 |
Have a nice day! |
Rotating Wall Problem Not Working | dreamchaser | CFX | 4 | September 29, 2014 10:09 |
Rotating Wall Problem for Elastohyrodnamic Lubrication | dreamchaser | Main CFD Forum | 0 | September 25, 2014 14:42 |
How to Apply Rotational Wall BC | tango711 | CFX | 3 | July 26, 2012 14:27 |
