June 21, 2018, 19:46 |
Particle injections, multiple scenarios
Itzel Marquez
I am trying to model different scenarios of particle injections in a wind tunnel. I have solved the wind velocity profile and I want to inject particles with different specifications. I believe there is a way to reduce calculation time and just solve for the DPM without having to solve for the velocity profile every time, but I have not found a way to do it. Do you know of a way to reduce calculation time if all I am changing is the specifications in the DPM? Thank you |
how to set periodic boundary conditions | Ganesh | FLUENT | 15 | November 18, 2020 06:09 |
Particle tracking error | alchem | OpenFOAM Bugs | 5 | May 6, 2017 16:30 |
Continous, multiple DPM injections to approximate particle volume fraction | mkamalhilmi | FLUENT | 0 | June 30, 2014 17:55 |
injection problem | Mark New | FLUENT | 0 | August 4, 2013 01:30 |
Multiple surface particle injections from the command line | mbeals | FLUENT | 0 | June 3, 2009 14:11 |
