July 2, 2018, 15:02 |
Continuity issues
Ramesh
Rep Power: 7 |
Hi everyone,
I am simulating flow past the airfoil NACA 0012 in ANSYS Fluent.I used SA model and the required conditions.The AMS was diverging.Then I changed to K-e model,and changed the second order variables to first order.It effected my continuity residuals.They are not converging,increasing instead. Please suggest a solution to this problem. Thanks in advance |
July 2, 2018, 18:49 |
Lucky
Rep Power: 66 |
Reset your residuals after you switched to the new solver.
I really suggest to read thoroughly through the documentation to understand what exactly are the residuals. The continuity residual is scaled by the worst imbalance in the first 5 iterations. When you switch solvers after iteration 100, that reference value is no longer relevant. It also means your continuity residual is dependent on the initialization. |
July 2, 2018, 23:34 |
Ramesh
Rep Power: 7 |
I forgot to mention that I did my meshing in Hypermesh and the mesh consists of trias(Unstructured mesh).But I have checked the quality and no element is failing in skew or the aspect ratio.Will that effect my solution in anyway? Thanks in advance. |
pimpleDyMFoam computation randomly stops | babapeti | OpenFOAM Running, Solving & CFD | 5 | January 24, 2018 05:28 |
How to write k and epsilon before the abnormal end | xiuying | OpenFOAM Running, Solving & CFD | 8 | August 27, 2013 15:33 |
Upgraded from Karmic Koala 9.10 to Lucid Lynx10.04.3 | bookie56 | OpenFOAM Installation | 8 | August 13, 2011 04:03 |
IcoFoam parallel woes | msrinath80 | OpenFOAM Running, Solving & CFD | 9 | July 22, 2007 02:58 |
Could anybody help me see this error and give help | liugx212 | OpenFOAM Running, Solving & CFD | 3 | January 4, 2006 18:07 |
