July 31, 2018, 12:15 |
Valveless Pulsejet
Andreia
Rep Power: 7 |
Hello I'm trying to simulate a valveless pulsejet using ansys fluent. My model is an advanced focussed wave type. I am using transient model, energy equation on, for the viscosityK-epsilon SST model , radiation: P1 and for the species partially premixed combustion . For BCs I have only one pressure inlet (here is a big part of my doubt) with gauss pressure 0 and mean mixture fraction 0.064 (I'm using a stoichiometric propane-air mixture). For the outlet I have pressure outlet also with gauss pressure 0 and progress variable 1. The walls are defined as convective.
My problem is that when I start running I can not get combustion, the fuel does not flow into the combustion chamber. What should I do? |
August 7, 2018, 15:42 |
Lucky
Rep Power: 66 |
Does it make sense for the inlet and outlet to be at the same pressure for this problem? What drives the flow?
August 8, 2018, 10:51 |
Andreia
Rep Power: 7 |
Yes you right, i've change the inlet pressure to 10.
Modelling Valveless Pulsejet | husni | FLUENT | 7 | March 31, 2018 05:06 |
Searching the optimum combustion model for pulsejet simulation. | Viento | CFX | 1 | February 4, 2018 05:30 |
Valveless Pump Boundary Load Convergence Problems in COMSOL v4.4 | PKawun | COMSOL | 0 | April 23, 2014 09:52 |
Modeling a pulsejet and an ejector | Emmanuel | FLUENT | 0 | May 24, 2006 18:53 |
modeling of a pulsejet in flight | Tony | CFX | 0 | August 30, 2005 17:31 |
