September 3, 2018, 10:56 |
Pressure Outlet vs Outlet Vent BC
James Wright
Rep Power: 10 |
For boundary conditions, what are the differences between Pressure Outlet and Outlet Vent?
Besides the loss coefficient, I can't really think of another reason why the Vent would be used over the Pressure Outlet. Main reason I ask is that I noticed that Fluent defaults to using the Outlet Vent BC instead of the seemingly more normal Pressure Outlet. Am I missing anything? |
September 3, 2018, 14:12 |
Lucky
Rep Power: 66 |
Actually the Fluent default when nothing is specified is a wall. It's only an outlet vent depending on the mesher you used that assigned it as an outlet vent.
Pressure outlet imposes a uniform static pressure on the outlet boundary. The outlet vent is just an pressure outlet (i.e. ambient pressure) with a loss coefficient. But the pressure drop is only in the direction of the flow so you can end up with a non-uniform pressure at the boundary if you have a non-uniform velocity profile. |
September 3, 2018, 14:51 |
James Wright
Rep Power: 10 |
I think I figured out why it was "outlet-vent" was the default for my boundary conditions. The name of those cell zones started with "outlet". I'm guessing Fluent does some kind of simple regex for the first characters of the cell zone to determine the automatically-applied Boundary Condition.
Thanks for the clarification! |
Pressure Boundary Inlet and Outlet | AS_Aero | CFX | 5 | March 28, 2018 10:46 |
Pressure inlet vs outlet position, transient, time dependent pressure and gravity | silent2608 | FLUENT | 0 | February 6, 2016 10:19 |
sonicFoam - pressure driven pipe: flow continuity violation and waveTransmissive BC | Endel | OpenFOAM Running, Solving & CFD | 3 | September 11, 2014 16:29 |
Unsteady pressure differential between inlet and outlet of the pipe for single phase | joshi20h | FLUENT | 0 | September 26, 2012 12:41 |
Hydrostatic pressure in 2-phase flow modeling (CFX4.2) | HB &DS | CFX | 0 | January 9, 2000 13:19 |
