September 7, 2018, 02:02 |
Heat Rejection Rate(negative&positive)
Onur Özcan
Rep Power: 12 |
Hello guys,
I have modelled porous core of intercooler and radiator for a vehicle. Also, heat exchanger module was activated and give there heat rejection rates with together primary and auxiliary fluid mass flow rate. Those cores releases heat and what should I give their value? positive or negative. In a similar way, there is also a core which has w/m3 and it release heat,too and its value in energy source term should be negative or positive?? Regards, Really appreciated!!! |
September 9, 2018, 11:56 |
Lucky
Rep Power: 66 |
It's a source term. Positive means heat is generated (a source), negative means heat is taken away (a sink).
Error - Solar absorber - Solar Thermal Radiation | MichaelK | CFX | 12 | September 1, 2016 05:15 |
Heat Release vs. Apparent Heat Release // Comparison with GT Power | MFGT | CONVERGE | 10 | August 17, 2016 02:38 |
UDF for Heat Exchanger model | francois louw | FLUENT | 2 | July 16, 2010 02:21 |
CFX Heat Transfer | RJamison | CFX | 0 | July 24, 2008 12:11 |
combustion in low heat rejection engine | M.MANI | Siemens | 0 | March 18, 2006 04:27 |
