Fluent Batch Mode error: No error handler available
Old   September 14, 2018, 01:29
Post Fluent Batch Mode error: No error handler available
Ali Haider
hahs is on a distinguished road
Respected Sir,
The story of error, which i encountered during simulating my solution problem in fluent batch mode. I connected my machine through Putty(SSH) to super computer. In batch mode my simulation start running successfully in background but as the Putty(SSH) session terminated (2 hours termination time of Putty). simulation stopped and it gave me this error.
Warning: An error or interrupt occurred while reading the journal file.
Some commands may not have been completed.
> Halting due to end of file on input.
Command which is used to run simulation in batch mode; nohup fluent 3ddp -t64 -g -cnf=M2.txt -mpi=intel -i input1.txt > output1.txt 2>&1 &
ant the input file command lines are:
; Read case file
rc ke.cas
; Initialize the solution
/solve/initialize/hyb-initialization
;Autosave data frequency
/file/auto-save/data-frequency
360
;Root Name
/file/auto-save/root-name
ke-std-as.dat
; Calculate 108000 iterations
/solve/dual-time-iterate
36000
3
; Write data file
wd ke.dat
; Exit Fluent
exit
OK
hahs is offline   Reply With Quote
batch mode, error, fluent, linux
Stopping a Fluent batch job AND saving the data! Possible? Volker Pawlik FLUENT 13 December 28, 2020 04:16
Fluent in Batch mode: How to repeat process? h0rst FLUENT 1 July 5, 2019 12:32
fluent 12.1, batch mode in linux sakalido FLUENT 13 September 27, 2017 08:55
Fluent batch mode unix : how do a patch? Claire FLUENT 0 February 12, 2013 10:06
fluent stops batch mode on error Ralf Schmidt FLUENT 1 March 1, 2008 10:35
