Tweaking settings to prevent divergence at high angles of attack |
September 14, 2021, 03:06 |
Adithya
Rep Power: 4 |
Hello
I am simulating the flow around an aircraft. Settings- SA turbulence model, coupled pressure-velocity with time factor 0.1, second order discretization. My simulations run well and converge at low and moderate angles of attack. However, it diverges at 10 degrees. I need to get results till 14 degrees as I expect the CL max to be achieved at 12 deg. I am thinking of tweaking some under-relaxation parameter, but not sure which one and by how much. Currently, they are left at default. Anybody would have any suggestions? Or, is it recommended to run a first order simulation, get a result, and then use that to initialize and continue with the second order simulation? |
Divergence detected in AMG solver. VOF. | Mr.Mister | Fluent Multiphase | 4 | September 25, 2023 07:10 |
viscosity udf don't use correct temperature and strain rate | rezvani | Fluent UDF and Scheme Programming | 8 | May 27, 2021 05:40 |
modelling inviscid 2D flow at high angle of attack | Ferdinando | FLUENT | 2 | October 30, 2007 17:26 |
Airfoil simulation in High Angles of Attack | Yasser Nabavi | FLUENT | 0 | April 21, 2006 17:28 |
Multicomponent fluid | Andrea | CFX | 2 | October 11, 2004 05:12 |
