Plotting contour lines of max. and min. pressure |
October 16, 2018, 11:09 |
Nourhan
Rep Power: 12 |
I am doing a simulation of wind flow around a building, I used LES and the time duration 2 seconds with time step 0.002s. I am using fluent16 version and CFD post for post processing. My question is how to plot the maximum (or average, minimum) pressure coefficient through the time history of 2secs? Thank you. |
October 17, 2018, 03:44 |
Leonardo
Rep Power: 8 |
If you want to Create a contour of max values you can create an uso-surface in Fluent. Just select pressure in the iso contour panel, then press compute, then write the number you are interested or scroll the bar. I think it's the same in cfd post.
November 21, 2023, 01:55 |
shristi
Rep Power: 2 |
I am doing a simulation of flow past elastically mounted cylinder in 3d. My question is how to plot the average pressure coefficient through the time history like t = 5sec in tecplot? |
y+ and u+ values with low-Re RANS turbulence models: utility + testcase | florian_krause | OpenFOAM | 114 | August 23, 2023 05:37 |
Cavitation around NACA hydrofoil using interPhaseChangeFoam | Kozan | OpenFOAM Running, Solving & CFD | 28 | March 11, 2023 23:30 |
Near wall treatment in k-omega SST | Arnoldinho | OpenFOAM Running, Solving & CFD | 38 | March 8, 2017 13:48 |
Problem of simulating of small droplet with radius of 2mm | liguifan | OpenFOAM Running, Solving & CFD | 5 | June 3, 2014 02:53 |
On the damBreak4phaseFine cases | paean | OpenFOAM Running, Solving & CFD | 0 | November 14, 2008 21:14 |
