Moving a wall at a frequency
Old   October 27, 2018, 14:05
Default Moving a wall at a frequency
Kimster
iceman53y is on a distinguished road
I am new to Fluent.
I am trying to oscillate a wall at a certain frequency in the horizontal direction.
It is a circular tube that I am trying to oscillate and see the effect of the lift and drag forces on the adjacent tubes at different flow velocities of water.
Some people have told me about UDFs. I don't know how to do that.
If there is an easier way please let me know or please walk me through creating a UDF.
Appreciate your help.
kind regards,
CFD noob.
iceman53y is offline   Reply With Quote
Old   October 29, 2018, 14:18
Lucky
Is the oscillation parallel to the flow? I.e. is there any squeezing effect?
You can just apply a time-dependent velocity to the wall. The velocity can be applied as a udf or even simpler a csv style profile.
Old   October 29, 2018, 22:54
Kimster
I've managed to start compiling UDFs without any issues now. Took me two days to get it working.
Appreciate if someone can share a UDF for oscillating a cylinder in cross flow at a certain frequency from its current location.
There is no squeezing effect.
Thanks
Old   October 29, 2018, 23:04
Kimster
Thanks
Old   October 30, 2018, 00:27
Default Udf
Kimster
This UDF is working but the cylinder moves to the right and comes back to same position, therefore is oscillating about a point towards the right of the origin point of the cylinder. I want it to oscillate right and left from its current location.
How would I change this code?
Please help.
/* Moving Grid problem - CG movement of a cylinder */
#include "udf.h"
static real velx = 0.0;
DEFINE_CG_MOTION(cylinder, dt, vel, omega, time, dtime)
NV_S(vel, =, 0.0);
NV_S(omega, =, 0.0);
velx = 0.005 * sin(3.1415927 * time / 5.);
vel[0] = velx;
decomposePar problem: Cell 0contains face labels out of range vaina74 OpenFOAM Pre-Processing 37 July 20, 2020 05:38
Use of moving wall in COMSOL? MultiPhy COMSOL 1 September 24, 2018 18:39
partial slip to moving wall ashokmoravaneni OpenFOAM 4 March 8, 2018 10:37
Rotating Cylinder (Moving wall vs Moving reference frame vs Sliding mesh) hamed.majeed FLUENT 2 January 17, 2017 12:18
Wrong flow in ratating domain problem Sanyo CFX 17 August 15, 2015 06:20
