Cryogenic Fluid from Nozzle onto a Plate (Evaporation) |
October 30, 2018, 05:31 |
Rep Power: 10 |
Proclaimer:
Please keep in mind that i have worked on Fluent for a couple of years now but I am fairly a beginner in Multiphase simulation. I've worked on flow simulation of turbine blades, foils... on Fluent before but never multiphase. Problem: I am currently simulating the flow of a cryogenic fluid through a nozzle onto a plate. Due to the difference in pressure and temperature with the environment, part of the fluid will evaporate. The cryogenic fluid is used to cool the plate which has a relatively high temperature and will also cause the fluid to evaporate. Questions: 1) Is this simulation feasible or does it need to be cut up into different simulations? (nozzle alone, flow onto plate alone) 2) Also, which model would be best to simulate this flow + evaporation? I've read online that the mixture model is probably the best but I don't really understand why. 3) Can any of you recommend good explanations/links on UDFs and how to write them? Thanks for the help! |
Time step unsteady nozzle flow, impingement on plate | taillanm | STAR-CCM+ | 4 | March 7, 2017 09:07 |
How to use fluent for fluid flow over flat plate where magnetic field is applied? | PAWAN009 | FLUENT | 0 | August 13, 2015 09:17 |
evaporation of drop on a heated plate | ztdep | Main CFD Forum | 0 | March 23, 2010 22:08 |
Terrible Mistake In Fluid Dynamics History | Abhi | Main CFD Forum | 12 | July 8, 2002 09:11 |
Fluid flow through a nozzle | DocB | Main CFD Forum | 5 | February 19, 2002 12:08 |
