November 7, 2018, 07:09 |
Channel Flow with different meshes
Lukas Hueckel
Rep Power: 7 |
Hi all,
I'm currently trying to model a rotating channel flow using FLUENT 17.1. The channel has the size 125.66x20x62.8 (x,y,z) in mm. First of all, i want to get the non rotating case in Agreement with the investigations of Grundestam, Wallin and Johannsson ("Direct numerical simulations of rotating turbulent channel flow") The boundary conditions for Inlet/Outlet and the side-walls are periodic. To maintain the flow I set a pressure Gradient in x-direction with the value -8.47 Pa/m for the periodic condition. I used a RANS-Simulation with the Reynolds Stress Model (default settings) and the pressure-based solver. As material I used the Fluent Default air properties. So now I have the following Problem with my results: If I use a coarse mesh, I will get a x-velocity-Profile at the outlet of my channel looking very similar to the results in the literature. when i use the mesh, which is used in the literature (way more refined than the coarse mesh), the Profile looks different an the values are lower. I attached some Pictures of the profiles. I thought there have to be nearly the same results, or even better results with the fine mesh. The Setup is identical for both simulations. Both simulations are using the simple scheme and FOU for TKE TDR and Reynolds Stresses. SOU is used for Energy, Momentum and pressure. What could be the reason for this behaviour? Your help is much appriciated! Regards, |
November 7, 2018, 08:52 |
Lucky
Rep Power: 66 |
Lower is an understandment... You have 5 m/s on the coarse mesh and 0.25 m/s on the fine mesh. The difference is more than an order of magnitude. Which one is closer to the correct answer?
I'm just going to say you should completely go over the setup again on whichever one is producing the most incorrect result. Probably you messed up a boundary condition or something. There's no reason for the results to be that different. |
November 8, 2018, 03:10 |
Lukas Hueckel
Rep Power: 7 |
Hi LuckyTran,
thanks for replying. The coarse mesh is very close to the literature. To be honest, I expected this answer. So I have asked a friend to compare the two setups and he also doesn´t found any differences. |
January 22, 2019, 06:46 |
王莹
Rep Power: 8 |
What's your simulation type? steady or unsteady? If it is steady simulation ,you can use SRF model. I have tried it and got the right curve.
June 20, 2020, 13:48 |
#5 | |
Rep Power: 7 |
For rotation, I introduce Omega=20 rad/s to both frame motion and wall (y=-h or h) at absolute frame. Is this how you did it too? |
LES/RANS on Channel Flow Velocity Profile | hx293 | Main CFD Forum | 15 | August 29, 2017 11:34 |
How to manage the pressure term in fixed mass flow rate based channel flow simulation | sjwon1991 | Main CFD Forum | 5 | July 10, 2017 07:21 |
rhoCentralFoam for channel flow | fportela | OpenFOAM Running, Solving & CFD | 22 | June 10, 2014 20:14 |
Gravitational water flow in closed channel. | Szymon85 | CFX | 7 | September 3, 2013 16:28 |
[ICEM] Flow channel meshing problems | StefanG | ANSYS Meshing & Geometry | 19 | May 15, 2012 06:44 |
