November 8, 2018, 14:04 |
Failure in initialization
Chen Sihe
Rep Power: 8 |
Hi all,
I am simulating a simple axisymmetric jet flow. However, when I tried to initialize, a floating point exception error pops up with AMG solver: ads-0. I surveyed quite a range of discussions online, and there are two types of advice: 1. Have a mesh with higher quality 2. Change the residual tolerance However, I both refined the mesh and also played with different residual, it seems that no difference is made. Does anyone know how to solve this problem? Or is there a good tutorial for axisymmetric jet simulation that I can take as an example? Thanks so much for your help guyz!:P |
November 8, 2018, 18:44 |
Lucky
Rep Power: 66 |
Well none of those recommendations affects initialization.
How are you initializing your case? Some setting there must be blatantly wrong for there to be a floating point error. |
November 8, 2018, 21:38 |
Rep Power: 10 |
Yeah... I'm with Lucky on this one. If your setup is encountering a floating point exception during initialization, then something major is wrong. Can you provide more info?
November 9, 2018, 00:40 |
Chen Sihe
Rep Power: 8 |
Hi LuckyTran and RaiderDoctor,
I have just read through the related ANSYS official documents... It turns out that the axisymmetric line must lie on x-axis. I think a lot of other guys have made similar error (including some of my friends). Sorry for this sort of novice question and have a nice day! |
November 9, 2018, 08:47 |
#5 | |
Lucky
Rep Power: 66 |
If you dig deep enough, you'll find a post where I also made the same realization. So yes I agree probably a lot of people have made this mistake. It's somewhat non-intuitive that there is a BC of type axis but the limitation that the actual axis of symmetry lie on x=0 you can only learn by reading the documentation. It would be nice if there is a more gentle reminder in the GUI or message printed to the terminal. Glad you figured it out. Last edited by LuckyTran; November 9, 2018 at 10:29. |
FMG initialization query | Mohsin | FLUENT | 6 | November 2, 2016 02:02 |
CFX Transient Initialization | frossi | CFX | 1 | June 17, 2016 09:31 |
Full Multigrid Initialization | Mr.Goodcat | FLUENT | 0 | March 17, 2016 06:43 |
Hybrid Initialization Failure | Persil | FLUENT | 2 | April 23, 2014 17:57 |
Pressure initialization Failure. | Nalleli | Siemens | 2 | August 31, 2005 06:28 |
