November 21, 2018, 03:17 |
Cut plane sector
MWRS
Rep Power: 8 |
How to cut a sector of a plane in Fluent for results? Like quadrant or 30 degree sector of circular plane?
November 21, 2018, 07:36 |
Tom David
Rep Power: 9 |
Under the Postprocessing tab in Fluent, in the Surface section (on the left), click create and isosurface. here you can create a surface of iso value of certain property. in your case the property should be mesh x,y, or z to create the plane cut. than you can create a transformed surface from the surface you have just created and rotate it to the angle of interest.
November 21, 2018, 07:38 |
MWRS
Rep Power: 8 |
Thank you so much. I will try this.
November 21, 2018, 07:39 |
MWRS
Rep Power: 8 |
After I make such iso surface plane, can I calculate area weighted average of a property?
November 21, 2018, 07:48 |
Tom David
Rep Power: 9 |
you can, but it might not be what you want, look at a contour plot on that surface to see if it looks like you expected, make sure it make sense.
Also, when you make the iso-surface, you can create it from one or more cellzone, or from the whole domain, if that helps. |
November 21, 2018, 07:49 |
MWRS
Rep Power: 8 |
Thankyou!
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
[ICEM] Stop cut plane from taking over control of scroll wheel | u2berggeist | ANSYS Meshing & Geometry | 10 | September 9, 2021 12:19 |
CFView: Cut plane | MarcoPolo | Fidelity CFD | 5 | February 5, 2019 03:05 |
Cut plane of nfaced cells | cfdbooks | EnSight | 16 | May 21, 2015 00:02 |
[ANSYS Meshing] Cut Plane Problem | cfdizzle | ANSYS Meshing & Geometry | 0 | December 4, 2014 15:54 |
