December 10, 2018, 09:47 |
Exhaust Gas Recirculation
abdo
Rep Power: 7 |
hello,I would like to conduct a simulation of premixed flame( reaction of propane-Air) with EGR...
my question is: how can i have EGR as addition in the premixed tube(i want to mixing the EGR with mixture(c3h8+Air)) by using fluent??because when i try to do this I received a lot of difficulties with boundary conditions ... plz some one help me? |
December 10, 2018, 10:15 |
#2 | |
Lucky
Rep Power: 66 |
You're mixing two/three mixtures... This is no longer a premixed flame. A premixed flame is described as a homogeneous mixture of reactants that magically (via combustion) get converted into products. There is no mixing of EGR with propane with air in a premixed combustion model. You need to check out the partially premixed or non-premixed combustion models. If the EGR gases are completely pre-mixed with the c4h4+air (premixed means it enters the domain/BC as an already mixed mixture), only then can you use a premixed model. |
December 10, 2018, 12:30 |
#3 | |
abdo
Rep Power: 7 |
thank you for reply to me,and i conduct a simulation of premixed flame (C3H8+Air) but i want to show the EGR effect in flame stabilisation,so I can add EGR in the combustor.. but the problem that I don't how to do this in fluent (like add the EGR tempreture and CO2 OR H2O mass fraction...) |
December 10, 2018, 12:45 |
Lucky
Rep Power: 66 |
You say you want a premixed flame... Okay...
Then you need to premix it yourself before you do anything in Fluent. Your new mixture is now c3h8 + air + egr gas altogether. Before mixing they'll each have their own temperature and pressure but after mixing they'll be at a single temperature and pressure. Figure out how to do this. This is not a Fluent problem but you can use Fluent to figure out how to mix these streams together if you like. |
December 10, 2018, 12:48 |
abdo
Rep Power: 7 |
yes I want to know how to do that...
can you help me? |
December 10, 2018, 20:46 |
Lucky
Rep Power: 66 |
December 11, 2018, 10:13 |
abdo
Rep Power: 7 |
hi,I take chemical equilibrium...
Setting the height of the stream in the free channel | kevinmccartin | CFX | 12 | October 13, 2022 21:43 |
Domain Reference Pressure and mass flow inlet boundary | AdidaKK | CFX | 75 | August 20, 2018 05:37 |
error message | cuteapathy | CFX | 14 | March 20, 2012 06:45 |
IC engines - Exhaust Gas Recirculation | Susan | Main CFD Forum | 5 | September 25, 2005 02:18 |
Gas pressure question | Dan Moskal | Main CFD Forum | 0 | October 24, 2002 22:02 |
