Please help with imported pressure!
Old   December 10, 2018, 10:43
Default Please help with imported pressure!
nicholas1339 is on a distinguished road
I'm encountering an issue with importing pressures from ansys fluent to static. Essentially, I'm trying to figure out the effects of the pressure over an aircraft and see what the stresses and deflection are.
I've imported the pressure by connecting the static module in workbench to the fluent module. The problem is, the mapped forces by static are larger than what they are supposed to be. The total lift force should be approx. 305N, which is the correct value from Fluent. But for some reason after importing into static and mapping onto the surface, the value is inflated to more than 500N.
Refer to the attached file for a view of the setup. Any insights into this mystery are appreciated!
nicholas1339 is offline   Reply With Quote
ansys, fluent, pressure, static, stress
Same pressure gradient but different velocity field TurbJet Main CFD Forum 22 April 28, 2018 03:35
Periodic flow using Cyclic - comparison with Fluent nusivares OpenFOAM Running, Solving & CFD 30 December 12, 2017 05:35
Pressure loss Velocity coupling CFXMUFFIN CFX 1 February 6, 2016 04:43
Discharge of Pressure Vessel into Pipe with Regulator gajowni2 System Analysis 0 October 31, 2015 18:57
Calculation of the Governing Equations Mihail CFX 7 September 7, 2014 06:27
