December 11, 2018, 06:48 |
Calculation Stopping Halfway
Jacob
Rep Power: 7 |
Hi Everyone,
I am currently doing a simulation on fluent. I first set to 1000 iterations. However half way at about 180 - 225 iterations it will automatically stop and show error like "MPI Application rank 0 killed before MPI_Finalize() with signal 9 The fluent process could not be started." and also "Error at Node 0: floating point exception Error at host: floating point exception Error: floating point exception Error Object: #f" The convergence graph is looking pretty good however towards the 180 - 225 there is a sudden high spike and then the entire calculation just stops. What could be happening? Thanks guys! Regards, Legolas |
December 11, 2018, 12:39 |
Lucky
Rep Power: 66 |
The MPI error is quite generic and doesn't really mean anything except that it says Fluent crashed.
The floating point exception means your case diverged. Unlucky! 200 iterations is not very many. The fact that your case didn't diverge before 200 iterations doesn't mean that it was converging. Figure out why you case is diverging and make the needed adjustments. Check boundary conditions. Check initial conditions. Check the mesh. |
calculation, convergence, iteration |
Dynamic mesh adaption in parallel calculation | xh110120 | FLUENT | 1 | March 12, 2016 08:05 |
Determining the calculation sequence of the regions in multe regions calculation | peterhess | OpenFOAM Running, Solving & CFD | 4 | March 9, 2016 03:07 |
Asymptotic stopping criterion is not working | rob50904 | STAR-CCM+ | 2 | January 28, 2013 08:25 |
MRF and Heat transfer calculation | Susan YU | FLUENT | 0 | June 2, 2010 08:46 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
