December 18, 2018, 05:08 |
two separated liquid "phases/flows"
Rep Power: 7 |
I am trying to model a flow of 2 liquids (both water) through a channel filled with air. I want them to spread in different directions (see below), which I tried by defining different momentum source terms. In my simulation the two water phases always mix up and flow downwards only (just the y-direction). I set up the eulerian multiphase model with 3 eulerian phases (air, water1, water2). At my inlet I set the volume fractions of both water phases to 0.5 and the same velocity. Do I have to set any phase interactions I forgot or use the discrete phase model to get a result as shown below? Thank you in advance! |
December 18, 2018, 07:33 |
Lucky
Rep Power: 66 |
The water|water part is not a multi-phase problem. This part alone (ignoring the air) you could solve using the species transport model, not the multi-phase model. You might even be able to simulate this using a passive scalar approach to track the different waters. This is an odd setup.
What are your boundary conditions? And what drives the flow? Is gravity enabled or what? I just can't follow the setup. |
December 19, 2018, 06:40 |
Rep Power: 7 |
Hey,
sorry for my late response. Thank you for your advise with the species transport model. I will have a look. My boundary conditions: I have one inlet zone at the top with both water phases flowing into my channel equally (volume fraction = 0.5) and a velocity of 0.01 m/s. The bottom of my channel is a presure outlet. The rest is wall. I want to model the flow over two inclined planes and flow is driven through gravity (like in the picture). Because the x-component of the gravity is different for both planes i try to model this a source term. My two water phases just dont split up. |
reactingTwoPhaseEulerFoam - stability of subcooled boiling simulation | Robin.Kamenicky | OpenFOAM Running, Solving & CFD | 20 | September 20, 2021 10:15 |
How to define a RGP file for liquid air? | eis | CFX | 2 | July 22, 2018 04:51 |
RGP file for liquid air | eis | CFX | 0 | April 22, 2010 10:34 |
radiation of molton liquid metal in enclosure | richard | CFX | 0 | April 8, 2008 15:43 |
Need some help for total liquid fraction | linus | FLUENT | 0 | December 19, 2006 03:29 |
