December 27, 2018, 13:38 |
UDF for y displacement
Mustafa
Need help
I am working on a Stirling engine , To describe the motion of piston , I have written a UDF for the y displacement or position . Is it correct * moving piston-CG movement of piston*/ #include "udf.h" DEFINE_CG_motion(piston,dt,y,time,dtime) { real x y = 0.06869+0.06496 * (sin(3.14*(x-0.22597)/0.54806)); } regards, |
December 28, 2018, 00:28 |
Alexander
Rep Power: 34 |
It seems, that your code is not correct,
use Ansys FLuent Customization manual for more information "Dynamic Mesh DEFINE Macros" best regards |
December 28, 2018, 03:21 |
Mustafa
Dear AlexanderZ
could you help me with correction of this udf ? Regards, |
December 28, 2018, 09:37 |
Rep Power: 7 |
You’re missing some variables such as omega I believe.
December 28, 2018, 09:40 |
Rep Power: 7 |
It should be DEFINE_CG_MOTION(whatever_name, dt,vel, omega, time ,dtime)
December 28, 2018, 09:53 |
Rep Power: 7 |
With that I also believe you should add vector placements. So your y should be vel[1] = whatever. [1] here saying the y direction. Omega should probably be added as well where it would be omega[2]=0.0 and I would probably even have a vel[0]=0.0. This may not be necessary.
Additionally, I do not think Ansys knows what “x” is here. Instead use vel[0] or you may have to look up in the manual what Ansys stores it’s positions as. I am unsure what your x is rather it is velocity or position. Best, RCamp |
UDF for vapor pressure | anuarun | Fluent UDF and Scheme Programming | 12 | December 24, 2021 10:12 |
Replicating Scalable Wall Function with a UDF | yousefaz | FLUENT | 0 | August 4, 2017 02:30 |
UDF in Fluent | Andrew | Fluent UDF and Scheme Programming | 5 | March 7, 2016 03:38 |
Displacement of particles with an udf | Michael Heim | FLUENT | 0 | July 6, 2004 14:08 |
UDF, UDF, UDF, UDF | Luc SEMINEL | Main CFD Forum | 0 | November 25, 2002 04:01 |
